Yesterday's Tractor Co. Fast, Friendly Parts Service
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Restoration & Repair Tips Board
Topic: Re: Running a 12 volt hydraulic pump on 6 volts????
[Show Entire Topic]  [Return to Forum]
wilsonsk
12-11-2012 16:17:17
208.54.80.246
thanks for all of the good info, if there is a chance of burning up the pump, I won't try it. I have a Ford alternator just need a voltage regulator, battery, coil and the time to do it. I may just hang the blade on the bucket so I can move some snow. thanks for the help.
[Reply]   [No Email]
old
12-11-2012 17:19:55
209.86.226.56
 Re: Running a 12 volt hydraulic pump on 6 volts???? in reply to wilsonsk, 12-11-2012 16:17:17
Shoot for around $50 you can buy an Delco alternator for say a 1980 Chev pick up no power any thing and that is a simple 3 wire hook up and then you do not have to mess with an external V.R which are a pain in the back sides any how
[Reply]  [No Email]
Glennster
12-11-2012 18:05:58
99.90.9.201
 Re: Running a 12 volt hydraulic pump on 6 volts???? in reply to old, 12-11-2012 17:19:55
Years ago they used to have a small 110volt generator tthat. Mounted to a car or truck engine like an alternator. It was all self contained, it would run a drill or skilsaw. Was a pretty handy deal. Would like to find one of them .
[Reply]  [No Email]
old
12-11-2012 18:19:40
209.86.226.34
 Re: Running a 12 volt hydraulic pump on 6 volts???? in reply to Glennster, 12-11-2012 18:05:58
Ya no all that common any more. A good many of those where DC so would run a drill etc but not things like a radio etc
[Reply]  [No Email]
wilsonsk
12-12-2012 06:09:27
75.149.150.49
 Re: Running a 12 volt hydraulic pump on 6 volts???? in reply to old, 12-11-2012 18:19:40
I agree the GM alternator is probably a better choice, but I have the Ford alternator and a VR is $15. I may as well use it. Need a coil and battery either way.
[Reply]  [No Email]
old
12-12-2012 08:26:41
209.86.226.34
 Re: Running a 12 volt hydraulic pump on 6 volts???? in reply to wilsonsk, 12-12-2012 06:09:27
You do not have to replace the coil all you do is add a ballast resister between the ignition switch and the coil O'Reilly's part number VR-1 works well and can be mounted to a thin piece of metal so as to have a heat sink and it cost less then $5
[Reply]  [No Email]
wilsonsk
12-12-2012 10:39:08
75.149.150.49
 Re: Running a 12 volt hydraulic pump on 6 volts???? in reply to old, 12-12-2012 08:26:41
I thought I needed a ballast resistor (or coil with an internal resistor) and a 12V coil vs 6V coil. Either way, it's probably a horse apiece, a 12v coil with internal resistor is $9.99, and I should put a new on on anyway.
[Reply]  [No Email]
old
12-12-2012 11:49:33
209.86.226.19
 Re: Running a 12 volt hydraulic pump on 6 volts???? in reply to wilsonsk, 12-12-2012 10:39:08
No such thing as a coil with an internal resister. The 12 volt coils are wound different so as to be a true 12 volt coil due to higher resistance in the way they are wound
[Reply]  [No Email]
LJD
12-12-2012 12:19:38
75.194.18.92
 Re: Running a 12 volt hydraulic pump on 6 volts???? in reply to old, 12-12-2012 11:49:33
Sure there is. All coils have internal resistors - i.e. the windings. A coil sold as not needing an external ballast resistor for a 12 volt system simply has the equivalent of the the external ballast resistor windings rolled into the internals.
Outside or inside - it's still a bunch of small wire windings to create resistance.
Regardless if a "6 volt" coil with separate resistor outside, or a "12 volt coil" with no outside coil of wire or carbon resistor wire (like GM and Deere use sometimes) - it will all total somewhere around 3-4 ohms on the primary.
[Reply]  [No Email]
old
12-12-2012 14:20:37
209.86.226.59
 Re: Running a 12 volt hydraulic pump on 6 volts???? in reply to LJD, 12-12-2012 12:19:38
But it does not have an internal resister as such so as I said I am correct.
[Reply]  [No Email]
LJD
12-13-2012 06:44:33
75.194.41.213
 Re: Running a 12 volt hydraulic pump on 6 volts???? in reply to old, 12-12-2012 14:20:37
I think we are talking in circles. The coil inside the can IS a resistor.
[Reply]  [No Email]
old
12-13-2012 10:03:23
209.86.226.27
 Re: Running a 12 volt hydraulic pump on 6 volts???? in reply to LJD, 12-13-2012 06:44:33
As per electronic terms as taught in such school no. It is wound in such a way so as not to have the need for a resister but the wire is not a resister but is just wound so that there is no need for a resister which it in fact 2 different things. Navy ET and electronics tek for decades as in since 1974. I have forgot man thing when it comes to electronics that few ever learned. If you understand electronics explain this. Bad Boys Rape Our Young Daughters But Violet Give Willing Lee
[Reply]  [No Email]
60 acre hillside
12-15-2012 14:54:41
67.142.170.23
 Re: Running a 12 volt hydraulic pump on 6 volts???? in reply to old, 12-13-2012 10:03:23
Digits for resistor values, There is no color starting with "D" but there is "G" for green Bad boys do not rape young daughters but they do rape young girls "G" Green band on resistor. Ok I guess every young girl is some dad's daughter.
I never had any trouble getting students to understand the color bands on resistors since I learned that.
60 Acre Hillside. Technology Teacher Applied Electricity (years ago)
[Reply]  [No Email]
old
12-16-2012 08:48:57
4.244.218.47
 Re: Running a 12 volt hydraulic pump on 6 volts???? in reply to 60 acre hillside, 12-15-2012 14:54:41
I learned that in Navy A school for basic electronics the went to B school for computer maintenance/repair. Learned to hate working on electronics so gave it up and did engines and welding and other hands on such. Boy have the computers changed since I use to fix them
[Reply]  [No Email]
wilsonsk
12-12-2012 12:46:58
75.149.150.49
Thanks for the info, that's good to know.
[Reply]  [No Email]
[Show Entire Topic]     [Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
