TractorLinks.com
Restoration & Repair Tips Board
Re: 1950 Farmall H
glennster
12-09-2012 19:18:15
check the tube from the governor to the carb. there is a slotted deal that needs to fit into the shaft coming from the governor. also, if you had the butterfly out of the carb on the main throttle shaft, be sure it is back in correctly.
wilsonsk
12-09-2012 19:53:57
 Re: 1950 Farmall H in reply to glennster, 12-09-2012 19:18:15
I did have the butterfly out, and replaced the throttle shaft. How do I check to make sure everything is correct, it was kind of a challenge getting the carb back on and the governor tube and linkage connected.
Steve
J.Wondergem
12-17-2012 06:36:58
 Re: 1950 Farmall H in reply to wilsonsk, 12-09-2012 19:53:57
I'm not acquainted with the governor to carburetor tube, but the butter fly in the carburetor has the edges at an angle. Make sure that angle matches the walls of the carburetor when closing.
