Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Restoration & Repair Tips Board
Re: farmall h starting problems
wilsonsk
11-28-2012 10:18:02
I'm new to the tractor world, but not to the world of internal combustion. You need air+spark+compression to run. Check Spark, check fuel, compression is harder to check, but less likely to be suddenly lost. I have started using a trick that works well to check for fuel, I use a propane torch (normally used for sweating pipe), DON'T LIGHT IT, open the valve and stick it in the air intake of the carb and try to start it, it'll fire if there's spark. Also very helpful in old low compression motors with updraft carbs when they have sat for a long time, it'll fire on the propane and start drawing fuel a lot faster than cranking....and cranking....and cranking.....
