TractorLinks.com
Restoration & Repair Tips Board
Re: Cleaning and maintaining good ground paths, best methods???
John T
11-25-2012 08:10:12
I can only say whats worked for me over many years and manyyyyyyyyyyy tractors (was a used tractor dealer)
NOT ALWAYS MIND YOU LOL BUT HERES THE BEST IN MY OPINION........ After I cleaned/ground down/polished or whatever it took to get to a good shiny (no paint or grease or rust) conductive case/frame member. I used stainless steel bolts nuts and the biting barbed star lock washers and good soldered and crimped terminals with heat shrink etc wires and terminations, then when all is done if you keep oxygen and moisture away oxidation/rust is greatly reduced, so a thin coat of silicone or other coating, then let it dry then paint over.
If you do it that way I neverrrrrrrr had connection problems later. Similar on battery posts if you use the felt washers underneath then top it all off with that red terminal coating I NEVER HAD CONNECTIONS GO BAD
Thats my story n Ima stickin to it,,,,,,clean bright shiny steel,,,,,,,stainless steel star lock washers and other hardware,,,,,,,,,soldered and crimped terminals,,,,,,,,,,,coat all to keep air and water away YOURE GOOD TO GO
John T
wilsonsk
11-25-2012 10:44:37
 Re: Cleaning and maintaining good ground paths, best methods in reply to John T, 11-25-2012 08:10:12
Thanks, I cleaned everything with the wire wheel on the grinder, bolted it all together and everything works great! I'll get it coated with something tonight. Now I need to go through the wiring, it has the 4 position L-H-D-B switch, and I'm assuming a cut out, it's big and square like a regulator, but appears to have 4 terminals, and one on the right side isn't used, just one wire going up to the box. It charges a little with the switch on H, but won't keep up with the lights, after running for a few minutes on H wide open, I get about 6.2 volts, ammeter shows a slight charge. I'm assuming it should be better than this.
Bob M
11-26-2012 15:05:34
 Re: Cleaning and maintaining good ground paths, best methods in reply to wilsonsk, 11-25-2012 10:44:37
If the cutout/regulator has 4 terminals, it's a regulator. And from your description (low charge rate, generator can't keep the lights and an open terminal on the VR) says the VR is wired wrong.
The regulator's BAT terminal should connect to the ammeter. And the regulator L terminal should go to the tractor's electrical loads ("hot" supply for both the ignition and light switches).
Punch the link below for a diagram.
wilsonsk
11-26-2012 16:58:50
 Re: Cleaning and maintaining good ground paths, best methods in reply to Bob M, 11-26-2012 15:05:34
It's definitely a cutout, and has a field resistor for use if there are no lights. I think I've got things working fairly well, I started another thread just for my charging issue.
wilsonsk
11-26-2012 16:59:55
 Re: Cleaning and maintaining good ground paths, best methods in reply to wilsonsk, 11-26-2012 16:58:50
http://ytforums.ytmag.com/viewtopic.php?t=965486
