Yesterday's Tractor Co. Restoration Quality Tractor Parts
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Restoration & Repair Tips Board
Topic: Cleaning and maintaining good ground paths, best methods???
[Return to Forum]
wilsonsk
11-25-2012 06:36:22
96.2.109.180
I just aquired my first tractor, a 1950 Farmall H. Runs great but the lights are not working, I'm cleaning everything up and finding they are fine, just dirty/rusty ground paths mostly. I'm cleaning parts with a wire wheel to get a good ground, is that the best thing to do? Is there something that will help conduct and keep the ground path clean? Whats the best way to maintain the lighting and electrical ground paths??
Thanks,
Steve
[Reply]   [No Email]
buickanddeere
11-27-2012 11:49:30
184.151.61.43
Re: Cleaning and maintaining good ground paths, best methods??? in reply to wilsonsk, 11-25-2012 06:36:22
There are times when just running a separate chassis return
cable is better than grinding through the paint. Or when there
are many bolted sheet metal joints.
  [Reply]  [No Email]
wilsonsk
11-27-2012 12:15:35
75.149.150.49
Re: Cleaning and maintaining good ground paths, best methods in reply to buickanddeere, 11-27-2012 11:49:30
We'll see how it holds, it's working fairly well now (7.2 volts on "H"). The belt is very loos as well, I didn't see how to adjust it at first, pretty clever. I didn't realize how it worked until I had the hood back on. It has a loader on it so removing the hood is a bit of a chore.
  [Reply]  [No Email]
John T
11-25-2012 08:10:12
216.249.82.117
I can only say whats worked for me over many years and manyyyyyyyyyyy tractors (was a used tractor dealer)
NOT ALWAYS MIND YOU LOL BUT HERES THE BEST IN MY OPINION........ After I cleaned/ground down/polished or whatever it took to get to a good shiny (no paint or grease or rust) conductive case/frame member. I used stainless steel bolts nuts and the biting barbed star lock washers and good soldered and crimped terminals with heat shrink etc wires and terminations, then when all is done if you keep oxygen and moisture away oxidation/rust is greatly reduced, so a thin coat of silicone or other coating, then let it dry then paint over.
If you do it that way I neverrrrrrrr had connection problems later. Similar on battery posts if you use the felt washers underneath then top it all off with that red terminal coating I NEVER HAD CONNECTIONS GO BAD
Thats my story n Ima stickin to it,,,,,,clean bright shiny steel,,,,,,,stainless steel star lock washers and other hardware,,,,,,,,,soldered and crimped terminals,,,,,,,,,,,coat all to keep air and water away YOURE GOOD TO GO
John T
  [Reply]  [No Email]
wilsonsk
11-25-2012 10:44:37
96.2.109.180
Re: Cleaning and maintaining good ground paths, best methods in reply to John T, 11-25-2012 08:10:12
Thanks, I cleaned everything with the wire wheel on the grinder, bolted it all together and everything works great! I'll get it coated with something tonight. Now I need to go through the wiring, it has the 4 position L-H-D-B switch, and I'm assuming a cut out, it's big and square like a regulator, but appears to have 4 terminals, and one on the right side isn't used, just one wire going up to the box. It charges a little with the switch on H, but won't keep up with the lights, after running for a few minutes on H wide open, I get about 6.2 volts, ammeter shows a slight charge. I'm assuming it should be better than this.
  [Reply]  [No Email]
Bob M
11-26-2012 15:05:34
69.207.86.27
Re: Cleaning and maintaining good ground paths, best methods in reply to wilsonsk, 11-25-2012 10:44:37
If the cutout/regulator has 4 terminals, it's a regulator. And from your description (low charge rate, generator can't keep the lights and an open terminal on the VR) says the VR is wired wrong.
The regulator's BAT terminal should connect to the ammeter. And the regulator L terminal should go to the tractor's electrical loads ("hot" supply for both the ignition and light switches).
Punch the link below for a diagram.
  [Reply]  [No Email]
wilsonsk
11-26-2012 16:58:50
96.2.109.180
Re: Cleaning and maintaining good ground paths, best methods in reply to Bob M, 11-26-2012 15:05:34
It's definitely a cutout, and has a field resistor for use if there are no lights. I think I've got things working fairly well, I started another thread just for my charging issue.
  [Reply]  [No Email]
wilsonsk
11-26-2012 16:59:55
96.2.109.180
Re: Cleaning and maintaining good ground paths, best methods in reply to wilsonsk, 11-26-2012 16:58:50
http://ytforums.ytmag.com/viewtopic.php?t=965486
  [Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
