TractorLinks.com
Restoration & Repair Tips Board
Re: 1957 Ford 600 carb bowl drain plug
rustyfarmall
11-21-2012 13:30:35
The drain plug is basically just a 1/8" pipe plug, available at most any hardware store, but from the way you describe it, maybe you're talking about something else?
BillRemski
11-21-2012 14:46:26
 Re: 1957 Ford 600 carb bowl drain plug in reply to rustyfarmall, 11-21-2012 13:30:35
Thank's Rusty. This is a lot bigger than 1/8 inch. I found a picture of it online in a listing for a repair kit and it's a brass plug with a conical seat, about 3/8 inch diameter at the threads. The one that's in there now is just a plain plug and it's steel and it leaks. I'm going to check the repair kit manufacturer site, if I can find it and see if I can order just the plug.
showcrop
11-21-2012 18:06:10
 Re: 1957 Ford 600 carb bowl drain plug in reply to BillRemski, 11-21-2012 14:46:26
A 1/8 pipe thread is about 3/8 diam. 1/2 inch is about 3/4, 3/4 is about one inch. Maybe somebody who is a plumber knows why.
Chavey
11-21-2012 20:14:54
 Re: 1957 Ford 600 carb bowl drain plug in reply to showcrop, 11-21-2012 18:06:10
re:pipe thread. pipes are measured on inside dia.for obvious reasons. so the outside thread has to be larger to allow for the pipe wall.
consequntially, a 1/2" pipe, schedule 40,will have an outside diameter of approx.3/4"
And so on for other sizes.
BillRemski
11-21-2012 19:24:42
I'll have to ask the neighbor, who's a plumber, why they are called what they are next time I talk to him. If it's a standard part I can see why the tractor part shops don't sell it.
rrlund
11-21-2012 15:07:59
A good hardware store will have that plug in brass. I'm not talking the hardware department at WalMart though.
BillRemski
11-21-2012 15:15:14
 Re: 1957 Ford 600 carb bowl drain plug in reply to rrlund, 11-21-2012 15:07:59
Thanks. After the holiday I will check the local S&H as they have a lot of hardware and fittings. I'll dig up the specs on it somewhere.
soundguy
11-24-2012 17:39:57
 Re: 1957 Ford 600 carb bowl drain plug in reply to BillRemski, 11-21-2012 15:15:14
yep.. 50 cent 1/8 pipe plug..
