| Author |
[Modern View]
| BillRemski
11-21-2012 12:21:43
24.231.199.19
The carb bowl drain plug on our Ford 600 started dripping gas. I have the shop manual but there is no part number listed for this and Steiner and Tractor supply only sell the part in a $60 kit. Does anyone know the specs on this part? If it is a standard size I can get it from a hardware supplier, but I can"t really get the specs from the plug that"s in there because it is just a cutoff machine screw from the looks of it and doesn"t have the conical seat at the end where it seals with the carb bowl casting. Thanks. |
| gab
11-21-2012 18:33:27
50.44.12.178
Re: 1957 Ford 600 carb bowl drain plug in reply to BillRemski, 11-21-2012 12:21:43
| Never had a ford carb apart, had an A/C and a half dozen Farmall carbs apart and they all have an 1/8 inch pipe plug for the bowl drain. If you have a decent tap and dye set it should have a 1/8 " pipe tap in it witch is about 3/8" in diameter to compare to what's in your carb. |
| BillRemski
11-21-2012 19:21:52
24.231.199.19
Re: 1957 Ford 600 carb bowl drain plug in reply to gab, 11-21-2012 18:33:27
| Thanks for the information. I don't know all the plumbing parts, but if this is a standard item I should be able to find it at the local hardware. Seems like a common item to lose considering how many times I had the one out of the old 8N. |
| rustyfarmall
11-21-2012 13:30:35
216.248.71.226
| The drain plug is basically just a 1/8" pipe plug, available at most any hardware store, but from the way you describe it, maybe you're talking about something else? |
| BillRemski
11-21-2012 14:46:26
24.231.199.19
Re: 1957 Ford 600 carb bowl drain plug in reply to rustyfarmall, 11-21-2012 13:30:35
| Thank's Rusty. This is a lot bigger than 1/8 inch. I found a picture of it online in a listing for a repair kit and it's a brass plug with a conical seat, about 3/8 inch diameter at the threads. The one that's in there now is just a plain plug and it's steel and it leaks. I'm going to check the repair kit manufacturer site, if I can find it and see if I can order just the plug. |
| showcrop
11-21-2012 18:06:10
75.67.231.80
Re: 1957 Ford 600 carb bowl drain plug in reply to BillRemski, 11-21-2012 14:46:26
| Quoting Removed, click Modern View to see
A 1/8 pipe thread is about 3/8 diam. 1/2 inch is about 3/4, 3/4 is about one inch. Maybe somebody who is a plumber knows why. |
| Chavey
11-21-2012 20:14:54
71.17.3.28
Re: 1957 Ford 600 carb bowl drain plug in reply to showcrop, 11-21-2012 18:06:10
| re:pipe thread. pipes are measured on inside dia.for obvious reasons. so the outside thread has to be larger to allow for the pipe wall. consequntially, a 1/2" pipe, schedule 40,will have an outside diameter of approx.3/4" And so on for other sizes. |
| BillRemski
11-21-2012 19:24:42
24.231.199.19
| I'll have to ask the neighbor, who's a plumber, why they are called what they are next time I talk to him. If it's a standard part I can see why the tractor part shops don't sell it. |
| rrlund
11-21-2012 15:07:59
207.241.137.116
| A good hardware store will have that plug in brass. I'm not talking the hardware department at WalMart though. |
| BillRemski
11-21-2012 15:15:14
24.231.199.19
Re: 1957 Ford 600 carb bowl drain plug in reply to rrlund, 11-21-2012 15:07:59
| Thanks. After the holiday I will check the local S&H as they have a lot of hardware and fittings. I'll dig up the specs on it somewhere. |
| soundguy
11-24-2012 17:39:57
184.233.63.143
Re: 1957 Ford 600 carb bowl drain plug in reply to BillRemski, 11-21-2012 15:15:14
| yep.. 50 cent 1/8 pipe plug.. |
