Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Restoration & Repair Tips Board
Re: FUEL TANK
Stephen Newell
11-16-2012 04:53:07
If your fuel is diesel you probably need to start with a bottle of diesel fuel tank cleaner. Also if your tank is gunked up your fuel lines and carburetor bowl may be gunked up also. You may need to replace the fuel lines and clean the carburetor bowl also. If the problem is rust you might start with a couple of pounds of screws, nuts and bolts shaking it a lot to break up the crust. Then flush with muriatic acid. The problem with muriatic acid is it quickly rusts back after treatment so use vinegar or oxalic acid to neutralize it. Then rinse the chemicals out with water and dry. Once a tank has started to rust it will continue so a fuel tank liner should be used to coat it. I use Red-Kote.
JMS/.MN
11-16-2012 08:42:18
 Re: FUEL TANK in reply to Stephen Newell, 11-16-2012 04:53:07
I mounted an old tank bracket on the cement mixer. Throw in the bolts and let it run overnight!
Stephen Newell
11-17-2012 05:24:52
 Re: FUEL TANK in reply to JMS/.MN, 11-16-2012 08:42:18
If a person was patient they could also throw the tank in the back of their truck for a few days. I had a fuel tank one time though that the bolts went through the tank. I had to cut the entire bottom out of the tank and weld another one in.
Copyright © 1997-2015 Yesterday's Tractor Co.
