Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Restoration & Repair Tips Board
ford naa starter
capy1958
11-14-2012 07:35:31
How do you get the pass thru bolt off starter of ford naa and install a new one.Thanks for help.
old
11-14-2012 07:50:43
 Re: ford naa starter in reply to capy1958, 11-14-2012 07:35:31
The NAA should have the flange mount type starter. The last of the pass thru type came on the 8N then they change to the flange mount so what tractor do you really have. As for how to do the pass thru you simple pull them like you would any other bolt then carefully slide the start out till you can install 2 nuts so the starter does not fall apart on you and then pull the starter. If it has the pass thru bolts they take a 5/16 nut
capy1958
11-14-2012 07:55:36
 Re: ford naa starter in reply to old, 11-14-2012 07:50:43
It is a naa ,I have starter off and it has a pass thru bolt that comes off from inside. I have rebuild kit for naa with new one.
