Yesterday's Tractor Co. Fast, Friendly Parts Service
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Restoration & Repair Tips Board
Topic: oil filter leaking
[Return to Forum]
ann budzinski
11-14-2012 05:55:11
208.126.128.142
I have a 560 Farmall tractor. I finally got the oil filter canister to
stop leaking from the base, but cannot stop the leak from the top
nut at the copper washer. Any ideas anyone???
[Reply]   [No Email]
d beatty
11-16-2012 11:53:19
24.12.128.253
 Re: oil filter leaking in reply to ann budzinski, 11-14-2012 05:55:11
There is a another way to stop it. Get an o ring that fits under the head of bolt and another one put between washer and canster. This has allways worked for me . You want to keep extra o rings because you will have to replace them every time you change oil filter.
[Reply]  [No Email]
Southern Ray
11-15-2012 18:11:11
76.228.38.39
mine was leaking too when I got it.
copper washer would not hold.
finally straighten it out best as I could with a brass rod and hammer.
I then brazed a thick washer onto the top.
Took it down to a local machine shop and had him put it in a lathe and true up the top of the washer.
haven't had any problems since.
[Reply]  [No Email]
ann budzinski
11-16-2012 08:59:35
208.126.128.142
 Re: oil filter leaking in reply to Southern Ray, 11-15-2012 18:11:11
I went to NAPA, Advanced Auto, Fastenal, and TSC...nobody has nylon washers that size! The washer doesn't look like anything is wrong with it. The NAPA guy suggested I use sandpaper to clean it up and try it again. Hate to go to the Farmall store and pay $6 for a washer! :(
[Reply]  [No Email]
wgm
11-21-2012 03:07:52
66.11.102.200
 Re: oil filter leaking in reply to ann budzinski, 11-16-2012 08:59:35
How much gas have you used running around trying to save a buck? Do yourself a favor and get the correct part or get used to the leak.
[Reply]  [No Email]
ann budzinski
11-16-2012 08:59:23
208.126.128.142
[Reply]  [No Email]
ann budzinski
11-15-2012 07:16:00
208.126.128.142
thank you so much. I'll buy a nylon washer and try it.
[Reply]  [No Email]
ericlb
11-15-2012 04:43:51
12.189.32.37
like the others have said the nylon gasket should help, take the old one with you to a good auto parts store, [carquest or napa] they usualy have a box of these and can size one up like yours so you get the proper inside and outside diameters,
[Reply]  [No Email]
greygoat
11-14-2012 08:07:30
69.179.6.109
Double washers ??? or, add nylon washer.
[Reply]  [No Email]
d beatty
11-14-2012 06:52:50
24.12.128.253
I have had the same problem with one one an M and 706. You could try a new washer or I had better results using a nylon washer.
[Reply]  [No Email]
rustyfarmall
11-14-2012 06:47:03
216.248.71.226
 Re: oil filter leaking in reply to El Toro, 11-14-2012 05:55:11
If you have already replaced that copper washer and it still leaks, chances are good that someone. at some point, has over-tightened the bolt, and thus the top of the canister is now mis-shaped and collapsed. Easiest way to fix that is to find another canister.
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
