HI, I got the 12 Volts all hooked up, gas tank on, the glass bowl is still leaking a little. I know I have ignition, but so far, all I can get is smoke out of the exhaust pipe and once, an impressive if short-lived flame from the carb air inlet (!). Perhaps I need to set the carb a little different? I have the small mixture screw 1 1/2 turns open; what about the big screw which angles up to the right? where should I set it?
I did not have the engine apart: I did replace the oil pan and removed the front cover to get out some broken bolts and change the front seal.
