Yesterday's Tractor Co. Tractor Parts for All Brands
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Restoration & Repair Tips Board
Topic: ford 961 ignition problems
[Return to Forum]
ford 961 mark
11-05-2012 09:50:27
12.106.100.170
Having trouble with my Ford 961 starting, I pulled the coil wire to check for spark and it fired up and ran great, then tried to put coil wire back in coil and it started to miss fire and stalled. does anyone have a clue.
[Reply]   [No Email]
soundguy
11-06-2012 16:43:41
173.104.255.18
Re: ford 961 ignition problems in reply to ford 961 mark, 11-05-2012 09:50:27
pulling the coil wire a bit opens the gap and makes for more KV
can fire thru a fouled plug.. or offset weak spark otherwise.
check er out.
  [Reply]  [No Email]
ford 961 Mark
11-05-2012 17:52:12
50.36.85.218
this tractor has become a frutration I blew a head gasket, I had head milled and rebuilt, installed new rod bearings and rings compression is 150 in all cylinders ,I have new plugs copper core wires and distributor But I know its something simple.
  [Reply]  [No Email]
Jon Hagen
11-05-2012 22:58:07
69.26.17.61
Re: ford 961 ignition problems in reply to ford 961 Mark, 11-05-2012 17:52:12
New plugs can still be fouled plugs, especially on starting a fresh engine. Try another set.
  [Reply]  [No Email]
Jon Hagen
11-05-2012 15:06:01
69.26.17.61
Sounds like you have badly fouled sparkplugs.
Pulling the coil wire partly out makes the coil build more voltage to fire through the increased gap of the partly pulled coil wire. This higher voltage is able to fire through the plug fouling.
Clean and regap or replace the sparkplugs.
It's an effective trick to remove the plug wire on a misfiring cylinder with a fouled plug, hold the wire a fraction of an inch from the plug terminal so the spark jumps the gap. This will often get the fouled plug firing so combustion heat can burn off the fouling.
  [Reply]  [No Email]
old
11-05-2012 10:08:24
209.86.226.34
Check your points they are either getting very bad or gaped wrong or some such thing. Points should be set at 0.025. Book says 0.024-0.026. When the coil wire is pull out say a 1/4-1/2 inch that caused the coil to build up high volts so you have a hotter spark so you have the common weak spark type problem which can be caused by many things like a cracked cap a rotor that is getting bad etc etc
  [Reply]  [No Email]
ford 961 Mark
11-05-2012 10:34:56
12.106.100.170
Re: ford 961 ignition problems in reply to old, 11-05-2012 10:08:24
My distributor is brand new but Idid not check the point gap. could it also be a bad wire?
  [Reply]  [No Email]
Kly
11-05-2012 11:26:52
64.147.38.17
Re: ford 961 ignition problems in reply to ford 961 Mark, 11-05-2012 10:34:56
I don't know what type of problem you are having. it could be a bad coil. Wires need to be either copper or stainless wire. Copper works best. That is what the tractors were designed to use. Modern wire sets do not work well with old tractors.
  [Reply]  [No Email]
old
11-05-2012 10:40:30
209.86.226.27
Well if you have the wrong type of plug wires yes they could cause it. On any tractor you need the true copper wire plug wires not the ones made for cars or truck since the ones made from cars/trucks are carbon wires and they do not hold up well to what a tractor has to put up with
  [Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
