JD 3020 Elec. problems
Louis Vogle
New User
I have a 3020 that has been conv. from 24v to 12v went to start it the other day turned key on and nothing works.The dash lights,head lights,starter won"t work.Batts. are good,can cross out starter and will turn over engine.Could it be a fuse or fuse link somewhere,got me stumped thanks for any help.
Louis
Did you wiggle the shift? Push it hard up against the top of "park". Don't they have a "park safety switch"?
We had a 4020 that had a fuse on the left side under that metal cowling over the dash. It would blow one every now and then and we would have problems like what you have. Sometimes it would take 2 or 3 fuses to make it finally work... good luck!
LonM
You have two circuit breakers inside the cowl cover down by your feet. Check for a bad connection or bad breaker.
