Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Restoration & Repair Tips Board
farmall m gas high rpm issue
Terry Nykamp
10-19-2012 07:31:04
tractors rpm is always at full throttle. i have adj. governor to spec,s with no help. when you pull throttle lever from #6 to # 1 no change in rpm,s do not see anything broken or missing ???
old
10-19-2012 10:09:34
 Re: farmall m gas high rpm issue in reply to Terry Nykamp, 10-19-2012 07:31:04
Fill in the gaps. What have you done??? If you have had the carb off you probably do not have the gov to carb hooked up correctly and the throttle linkage to gov is not in the correct slot
buickanddeere
10-19-2012 10:07:55
Throttle blade is stuck wide open? Or is the governor controlling the throttle blade and keeping rpms at fast idle?
flambeauone
10-19-2012 09:47:55
Have you had the carb off? Sounds like the linkage from the governor is not engaging the butterfly.
Copyright © 1997-2015 Yesterday's Tractor Co.
