Yesterday's Tractor Co. We Have the Tractor Parts You Need
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Restoration & Repair Tips Board
Topic: Re: Newly Overhauled Engine Somewhat Tight
[Show Entire Topic]  [Return to Forum]
Robert major
10-17-2012 15:55:59
216.81.1.152
Hi
I had this argument with a know it all guy that worked in a local shop once. He said an engine if its done right should always start first time with a battery. I called BS and walked away.
6 weeks later he had done a motor, I was in there and he had flattened 5 new batteries and was boosting the last one. I told him if he towed it it would start in 10ft or less,the shop owner heard me and he told guy to do it. 8ft and it ran like a watch, stopped it after a few mins and fired next time with the starter. 1 in 10 I do wont start and we tow them first time, so this can happen from my and dads 50 odd years experience.
Regards Robert
[Reply]   [No Email]
Wascator
10-18-2012 16:51:29
70.195.192.81
 Re: Newly Overhauled Engine Somewhat Tight in reply to Robert major, 10-17-2012 15:55:59
I remember installing the pistons in this engine (Continental F-162): I did not have to drive them in or anything like that, but there was significant friction which obviously came from the rings. The oil rings are the type which use an upper and lower thin ring with an expander behind. They are designed to wear in very quickly. I checked the end gap of each individual ring in the bore where they were installed, but as I recall there is no end gap on these oil rings.
In short: I am not surprised at the amount of friction in this engine, given my experience installing the pistons.I've barred it around probably 25-30 revolutions, timing the magneto, etc. It has compression in each cylinder, and it does not have any particular tight spots. The block was bored and honed, and the crank was inspected and polished, in a professional shop long in business and of high repute. Since I can't tow-start a Lincoln welding machine, I wonder how I'll ever get it started.
[Reply]  [No Email]
Mike M
10-30-2012 13:45:48
24.140.0.120
 Re: Newly Overhauled Engine Somewhat Tight in reply to Wascator, 10-18-2012 16:51:29
I'd be concerned about the end gap on the oil rings. The expander may not be in right or the thin rings not sitting right ?
I also go thru and check out the starters,alt. or gen.,water pumps & radiators on any engine job I do because the engine is going to crank harder and run hotter then when worn out.
I can't say as I have ever had trouble starting a fresh rebuilt engine. I crank them up without spark plugs or injectors to get oil pressure first too. Also use engine assy. lube on them when going together.
[Reply]  [No Email]
David G
10-18-2012 18:16:47
205.215.206.18
If the starter, connected normally, with a charged battery will not turn it over then something is wrong. It can take quite a bit of effort with a bar to turn over a new engine.
If you still have the pan off, make sure the rods are not binding. The rods on my 44 were not reconditioned correctly, and caused it to bind. I got them fixed and it is fine.
What did you gap the rings to?
[Reply]  [No Email]
[Show Entire Topic]     [Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
