Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Restoration & Repair Tips Board
Re: '44 John Deere A
Gene Davis (Ga.)
10-14-2012 18:48:57
Won't work because of the way the steering mechanism on the JD is built. Check the 90 wt. oil in the steering sector and the thrust bearing in the bottom of the pedestal. Has anyone greased the bottom bearing fitting lately?
JohnDeereM50
10-24-2012 20:10:51
 Re: '44 John Deere A in reply to Gene Davis (Ga.), 10-14-2012 18:48:57
Actually you can put power steering on it. You have to cut steering shaft and coupler steering motor to it and add a hydraulic pump that runs off of magneto or distributer. Lots of people have done it.
Myers Adam
10-22-2012 06:51:06
Thanks Gene.
We put a new sector gear in and re-adjusted the accentric. Also put corn head grease in the steering box.
Bottom was greased regularly. (The gear was badly worn).
The steering is much better and now satisfactory.
Thanks, Myers
