Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Restoration & Repair Tips Board
Re: bush hog problem
ericlb
10-11-2012 05:54:06
yes interesting, ive done it both ways the reason to heat is to destroy the rust and corrosion making the nut difficult to remove also heat expands the nut slightly making it easier to remove, at out company shop we use heat and remove the nuts ect while hot, these nuts are on mining machinery and equipment ie dozers loaders excavators ect and due to the wear are usually destroyed when its time to replace cutting edges and tract components ect even when the track pad bolts look good they usually will not budge without heat and most of the time have to be cut off then replaced in full, bolt and nuts and thats not cheap, been doing that since the early '70's
