TractorLinks.com
Restoration & Repair Tips Board
Re: bush hog problem
ASEguy
10-10-2012 04:36:17
If you are good with and air chisel, you should be able to get the nut off without damaging the threads on the shaft. If not, use heat on the nut to back it off. Once it gets moving don't stop until it's off. Gerard
Robert major
10-10-2012 21:04:09
 Re: bush hog problem in reply to ASEguy, 10-10-2012 04:36:17
Hi Just a small comment on removing the nut with heat. I"ve been in the shop trade over 30 years and never remove nuts from threads while hot I always let them cool or cool them with water before moving them. there is a huge risk that the nut will bind and destroy the shaft threads, I always go steady too so you can feel if things are not right, even to the point of heating and cooling more than once if needed its suprising how that alone will help loosen the nut on the thread. In my years ive seen more than one shaft messed up by moving nuts hot and guys not listening to what they where told lol. Regards Robert
ASEguy
10-11-2012 04:46:01
 Re: bush hog problem in reply to Robert major, 10-10-2012 21:04:09
Hello Robert. Interesting comment. I've never encountered that in automotive. I'll keep your suggestion in mind. Gerard
Robert major
10-12-2012 11:49:06
 Re: bush hog problem in reply to ASEguy, 10-11-2012 04:46:01
Hi Gerald My trade is Agri, we see this quite often with guys and now more so with guys watchin the vids on "tube and thinking they can change "muffler bearings" and do there own repairs. its not owning the tools thats hard its the knollage to use them that's the problem L.O.L. It is one of those things that you may of been lucky with and one day you might not be i guess. Now you can't get an empty bag outta a dealers for less than $20 i dont chance it with part prices.
Regards Robert
ericlb
10-11-2012 05:54:06
yes interesting, ive done it both ways the reason to heat is to destroy the rust and corrosion making the nut difficult to remove also heat expands the nut slightly making it easier to remove, at out company shop we use heat and remove the nuts ect while hot, these nuts are on mining machinery and equipment ie dozers loaders excavators ect and due to the wear are usually destroyed when its time to replace cutting edges and tract components ect even when the track pad bolts look good they usually will not budge without heat and most of the time have to be cut off then replaced in full, bolt and nuts and thats not cheap, been doing that since the early '70's
