Yesterday's Tractor Co.
Shop Now View Cart
Restoration & Repair Tips Board
Re: JD A
El Toro
10-08-2012 06:32:03
If you have dowels on that tractor they may be the problem. If you're using a suitable hoist to lift the engine you could sway the block from side to side easily so don't break anything. You also may need to support the rear of the tractor under the drawbar to keep it from flipping backwards once the engine is pulled. You may see a slight opening at the dowels from the swaying and you can use a pinch bar or big screwdriver to move the engine off the dowels. I would use lubri-plate on the dowels when reinstalling the engine. Hal
Kent Petersen
11-21-2012 10:37:41
 Re: JD A in reply to El Toro, 10-08-2012 06:32:03
from what you are telling this guy i know that you dont know the frist thing about a John Deere 2 cyl whay not saved it for the ones you do know something about
