TractorLinks.com
Restoration & Repair Tips Board
Re: Farmall B Left Brake Issues
Morris Krodle
10-07-2012 19:41:05
I just went thru a "45 B, new brakes etc. Sound like the shaft that the pedal is on is still seizing, that shaft also hinges the clutch and has a support on the trans tube that need lube,also since it"s the left side, the brake and drum are right nest to the trans and likely you have a trans seal leaking oil. Look under the axle housing and clean out the drain hole to insure oil is present. It"s not too hard to replace the brake and seals on either side.
