| Restoration & Repair Tips Board |
Topic: STARTING MY 8N AFTER 2 YRS.
[Return to Forum]
| Author |
[Modern View]
| LARRY CAIN
10-04-2012 09:11:32
99.195.207.8
BOUGHT A 1950 8N THAT HAS SIT FOR 2 YRS. OWNER SAYS IT RAN WHEN HE PARKED IT. WHAT SHOULD I DO TO IT BEFOR TRYING TO START IT? |
| Phil9N3667
10-07-2012 18:18:34
64.12.116.208
Re: STARTING MY 8N AFTER 2 YRS. in reply to LARRY CAIN, 10-04-2012 09:11:32
| Larry, if you want really good advice on this besides the other good previous replies, go to the 9N/2N/8N board! You can also download BruceVa's 50 tips to help you out. |
| BDT in Minnesota
10-07-2012 09:00:54
66.87.7.116
| Two years is not that long.... check All the fluid levels, drain the carb and clean the sediment bowel if needed, check the air cleaner, and battery condition.. ... Try staring it.. Bring a can of fresh gasoline along, |
| old
10-04-2012 15:25:06
209.86.226.40
| #1 loose the cap lock people do not like to be yelled at. #2 put say a 1/4 cup of ATF in each cylinder and let it sit over night that way. #3 clean the points or replace the points. #4 pour some gas in the tank and pull the carb drain plug and let some gas flow out of the drain plug hole. Catch it to use it and make sure it is not full of rust from sitting so long. Then give it a go and it may just run |
| GlenIdaho
10-04-2012 15:23:04
75.174.121.91
| I would go a little farther by checking the air filter for debris and/or nests, clean and re-oil; pull the plugs and put a cup of atf mixed with diesel in each cylinder and let it sit for a day or two to loosen and lube the rings; then remove fluid (may have to pump it out by cranking engine); at the same time look for any water in the cylinders; while you're at it do a compression test; check radiator for any obstructions; check trans, etc for water, if found drain and replace. Check engine oil for water/anti-freeze and replace oil and filter; Check each plug, clean and regap; check all electrical connection to make sure bright and tight. That should get you going. |
| Andy C
10-04-2012 14:57:46
71.246.21.89
| Heck! Check the oil and coolant and put a gallon of gas in it. Then put a battery in it or tow it off and see what happens! Pretty good chance it will start. Good Luck and let us know, Andy |
| Randy Roberson
10-24-2012 13:07:50
146.130.64.165
Re: STARTING MY 8N AFTER 2 YRS. in reply to Andy C, 10-04-2012 14:57:46
| Started one just like it a few months ago. Engine was free, cleaned out the gas tank, carb (carb has to be clean or it won't run right, ask me how many times I took this one apart)put in a battery, points and plugs, and busted her off. She ran very nicely, too, they are sweet, gentle machines when they are halfway right. Engine stuck: try oil in the cylinders (usually only one cylinder is the problem) and try rocking or moving the crank with a wrench or bar. Get too rough and maybe break a ring. |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
