TractorLinks.com
Re: priming the fuel system
Dodgeit
09-24-2012 13:10:12
What you need to do is crack all the fuel lines, from the pump to the injectors. As you are pumping the hand pump, start closing the ones that are oozing fuel. Starting at the pump, and working your way to the injector. Once all the connections in a line are bled, that injector is ready to fire. sometime it helps to crack the return line as well.
Once it is running, crack each connection at the injector, to finish bleeding air out of the system. When it quits sounding like marbles bouncing around inside the engine, retighten the connections.
You may need to do this a time or two to get all the air out.
If your not getting fuel, to the primer pump, try using an air hose in the tank opening to pressurize things abit.
