TractorLinks.com
Restoration & Repair Tips Board
Injector pump head port sequence
Gil from CA
09-22-2012 13:48:58
Does anyone know of where there is a diagram showing the sequence of ports (as far as which cylinder goes to which port) for a Bosch PSB-6A-80C diesel injector pump.
Tramway guy
09-25-2012 05:14:50
 Re: Injector pump head port sequence in reply to Gil from CA, 09-22-2012 13:48:58
If you can find any of the lines that make it clear which port it fits, and know which direction the pump rotates, the firing order is 1-5-3-6-2-4. It's a matter of the process of elimination, sort of.
DeltaRed
09-23-2012 08:31:07
Should be pretty much self expanetory.Each prebent line will only go to one cylinder.Think of it as a puzzle of sorts.
Gil from CA
09-24-2012 10:33:58
 Re: Injector pump head port sequence in reply to DeltaRed, 09-23-2012 08:31:07
I'm aware of that fact. It's when the lines don't exactly match the the ports in the head, if you see what I mean. I've checked the Bosch manual (on-line) and it doesn't show where the ports in the head go to which cylinder.
