Field Marshall Series 3
Anonymous-0
I need to remove the flywheel on a series 3 Field Marshall. I made a wedge to remove the two large keys on the crankshaft, but no luck in getting them to move. Any suggestions/tips on how to remove the flywheel would be appreciated.
(quoted from post at 23:13:53 09/19/12) I need to remove the flywheel on a series 3 Field Marshall. I made a wedge to remove the two large keys on the crankshaft, but no luck in getting them to move. Any suggestions/tips on how to remove the flywheel would be appreciated.
Heat and Kroil in abundant doses. Also should be a way to put a puller on the flywheel. Keys may only go in and out in one direction.
