Yesterday's Tractor Co. We Have the Tractor Parts You Need
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Topic: Re: 1973 Ford 4400 wiring diagram
[Show Entire Topic]  [Return to Forum]
JMOR
09-19-2012 08:38:21
72.181.173.171
Quoting Removed, click Modern View to seeSince I only have diagrams for 2000,3000,4000 and 4100,4600, etc. AND not for your 4400, "certainty" is a missing factor here. Sure would be nice if owner of 4400 diagram would pop up, but......
Given that, since you replaced the solenoid, you are almost certainly correct in that one of the wires got put back in the wrong place. The 4100 & 4600's used a ballast resistance between the key switch and the ignition coil AND used a terminal on the starter solenoid to bypass that resistance during starting........ I expect that the ign coil bypass wire is now connected to the battery terminal on the solenoid and NOT the start-bypass terminal, as it should be. Probably should be only one wire besides battery cable on that large solenoid terminal.
[Reply]   [No Email]
JWinnett
09-19-2012 12:47:54
170.54.58.4
Re: 1973 Ford 4400 wiring diagram in reply to JMOR, 09-19-2012 08:38:21
I'll know more tomorrow but there are for sure 3 wires on that one battery terminal. There is a ballast resistor on my 4400 also. I know one of the wires ends up in a loom but I should be able to tell you which ones go to the ing coil, solenoid coil, starter contacts, and ign switch tomorrow, possibly tonight if I get on a PC at home.
I appreciate your help!
James
This post was edited by JWinnett at 12:48:17 09/19/12.
  [Reply]  [No Email]
JWinnett
09-20-2012 05:32:21
170.54.58.4
Re: 1973 Ford 4400 wiring diagram in reply to JWinnett, 09-19-2012 12:47:54
Ok, I dismantled the tractor last night to get to the wiring. What a mess!
There are 3 wires from the supply side of the solenoid; A red wire from the Ing. coil, a Brown wire from the "B" terminal of the Generator regulator, and the battery cable from the + side of the battery. The load side of the solenoid goes to the starter. There is a Red/White wire from the key switch to one side the coil on the solenoid and the other side of the coil is a yellow wire running to a light switch???.
There is also another Red wire from the Ing. coil to the ballast resistor and from the Ballast Resistor, a Brown and Red wire to the key switch.
As a side note the wiring on top of the gas tank must have been real hot at one time because most of the wires have been spliced with green wires. The Brown/Red wire is bare where it goes over the gas tank right now so I will need to replace that wire. There are also some wires that can be eliminated as they are spliced in making one long wire that could be half the length. A rewire is definitly going to follow getting the key switch to shut the tractor off.
Any help and advise is welcome and I appreciate it all!
Here is a drawing of what I found lastnight.
James
This post was edited by JWinnett at 05:43:09 09/20/12.
  [Reply]  [No Email]
[Show Entire Topic]     [Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
