I have a Hesston 466DT tractor, about a 1985 model. I"ve had it some 20 years, and had very few problems. Recently, the steering will intermittently fail to turn to the left. If I turn it back to the right, and then back to the left, sometimes it goes ahead and turns. Sometimes it takes a couple of turns back and forth before it turns. This can be really scary sometimes. More recently, it has started to fail to turn to the right every now and then, but not as often as the left turn problem. I worked on a lot of things from motorcycles to airplanes,, but never any "full time power steering" setups. It kinda seems like a check valve sticking. I drained it, and flushed it with ATF, and refilled with the specified fluid, but it didn"t help. ANYONE have any experience or ideas ?
Thanks, Gary
Thanks, Gary
