Yesterday's Tractor Co.
Shop Now View Cart
Restoration & Repair Tips Board
ford 5000 power cylinder leak
09-04-2012 13:35:45
hi i have a 69 ford 5000 and it has a power cylinder leak. i believe i have to get it rebuilt. my question is how do you get it out? and is there a rebuild kit available??
09-06-2012 04:26:00
 Re: ford 5000 power cylinder leak in reply to nickkalisz, 09-04-2012 13:35:45
When you say that it is on the front end and you imply that it is difficult to get a,t it sounds like you have a wide front 5200 which is high platform row crop version. If so, the cylinder is under the radiator, so you will need to remove the front housing and radiator to get at it as well as the bell crank underneath that the tie rods attach to. Not a tough job, just takes time. Don't take it to CNH take it to a local hydraulic repair shop for rebuild.
09-04-2012 19:09:44
Don't know what you are referring to by power cylinder.
09-05-2012 08:05:07
 Re: ford 5000 power cylinder leak in reply to showcrop, 09-04-2012 19:09:44
for the power steering there is the pump and on the front end where the tie rods are connected there is the power steering cylinder which is leaking
