Yesterday's Tractor Co.
Shop Now View Cart
Restoration & Repair Tips Board
Re: carburetor
09-01-2012 09:46:14
If your talking about the down pointing main jet adjustment needle I would try dropping the whole carb in a can of carb cleaner which you will need any how and let it sock a couple days that way and that might be enough to free it up. Other wise if you try to drill it out and brake it you could be looking for the bottom half of a carb
joseph moore
09-01-2012 15:42:24
 Re: carburetor in reply to old, 09-01-2012 09:46:14
my problem is the needle valve assembly that unit that is screwed into the bowl will not come out..I will try heat also, the carburetor is out and I have used all kinds of spray rust disolvers.that is why I thought of drilling it out.
09-02-2012 08:57:04
 Re: carburetor in reply to joseph moore, 09-01-2012 15:42:24
If your not talking about the down pointing main jet adjustment needle but instead the main jet it self I never remove them I clean them where they are and have only had problem once in a while with doing it this way. I simply use a small wire and spray carb cleaner to make sure it is open and lots of compressed air
60 acre hillside
09-03-2012 07:35:53
 Re: carburetor in reply to old, 09-02-2012 08:57:04
It sounds like he is trying to remove the seat of the float valve. I never heard it called a jet and most kits do not include the jets
09-03-2012 08:20:55
 Re: carburetor in reply to 60 acre hillside, 09-03-2012 07:35:53
Ya he is not real clear as to what he is trying to take out. From what he is saying it could be 2 or 3 different parts
