TractorLinks.com
Restoration & Repair Tips Board
Re: John Deere loader very slow to raise
ERIC BENTON
08-30-2012 09:06:23
You may have a loader with a open center hydraulic valve on it. Some of them have a plug you can put an oring on and change it to a closed center valve. The easy way to check this is to crank up the tractor and just let it run for 15-20 minutes and then put your hand on the loader control valve. If it is really hot or will burn you then you have a open center valve and you are dumping (hi pressure internal leak)your hydraulic right back into the filter cover. On a closed center system the valve should be barely warm .
