leon lumsden
New User
replaced hyd.loade lift and tilt hose on model 800
ford,my ? where do i add the new hydraulic fluid,and
if it needs bleeding where and how do i bleed
hoses.thank for all helpful solutions
A lot more info is needed for use to be able to help you help your self.
Are you talking about a loader?? Does it run off the on board hyds or does it have a crank shaft driven pump?? If it has a pump up front run off the crank shaft a good number of them have the tank built into the loader frame and you should see a breather or pipe plug on the area where the hoses come out. That is where you fill it. As for bleeding it will do it on its own as you move the cylinder in and out
added new hyd. oil to fill spout,after replacing broken hose,tried to raise and lower loader bucket.noting happened,added 4 gals of fluid,
Again your leaving out info so hard to help you with out you filling in the blanks
