| Restoration & Repair Tips Board |
Topic: Re: Engine Timing help, Please
[Show Entire Topic] [Return to Forum]
| Author |
[Modern View]
| welding man
08-18-2012 12:59:23
76.9.225.76
A NAA times at 8 deg BTDC. Forget about the 31 Deg for now. Take # 1 spark plug out. Hold your finger over the hole and bump the starter over until it blows out the hole. Check to see where the timing marks are and turn the flywheel until you get it at 8 deg BTDC. Now check to see where the rotor is and post back. DO NOT Pull the dist out yet !!! |
| WVKid
08-18-2012 13:46:20
71.178.204.47
Re: Engine Timing help, Please in reply to welding man, 08-18-2012 12:59:23
| I pulled the #1 plug, got nice compression and turned the flywheel to 8 degrees, the rotor is now pointing between the #3 and #4 plugs.
What does the "B' stand for in BTDC, top dead center? Hate to show how much I don't know. lol |
| welding man
08-18-2012 15:22:23
76.9.225.76
Re: Engine Timing help, Please in reply to WVKid, 08-18-2012 13:46:20
| B stands for Before.How long has it been since the tractor has run and what makes you think it is out of time? There is lot of other things that could keep it from running besides being out of time. |
| WVKid
08-18-2012 15:43:05
71.178.204.47
Re: Engine Timing help, Please in reply to welding man, 08-18-2012 15:22:23
| Quoting Removed, click Modern View to see
It's been two years under my garage without running.
90% sure it's the timing. Replaced all the wiring, rebuilt the Carb, the Starter, Generator and lots of other stuff. When I change to heavy cable for the starter and battery the cranking RPM's doubled.
Was cranking the engine for about 2 minutes with no sign of starting when the carbuertor back fired. No smoke or fire just a loud noise. Someone told me that I might have damaged the floats in the carbuertor, checked it out and all is fine, put floats in a pan of water and they do float.
You name it and it's been replaced including radiator, ignition switch, gas tank, fuel bowl and fuel line.
Waiting on new gaskets for the carbuertor and if I can get the timing back I think she will be ok. When I pulled the #1 plug and did that compression test with my finger on the plug hole, it blew my finger away with good compression.
That about covers it to date.......Can I send you a picture, she looks good.
Thanks,
WVKid |
| Welding man
08-18-2012 18:16:53
76.9.225.76
Re: Engine Timing help, Please in reply to WVKid, 08-18-2012 15:43:05
| If it back fird, timing may not be off very much, loosen the distributor and turn it in both directions while cranking and see if it will start. Where are you located in WV. I also live in WV.my E-mail is open. |
| WVKid
08-18-2012 20:09:25
71.178.204.47
Re: Engine Timing help, Please in reply to Welding man, 08-18-2012 18:16:53
Not sure how to loosen the distributor, there are two set screws below the oil port of the distributor, if I back them out will that let me turn the distributor?
I'm in Stafford VA now, born and raised in the southwest part of WV, (Hatfield/McCoy area) all my people were coal miners. Went to Welch high school, just old and ugly now. lol
Thanks |
| [Show Entire Topic]
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
