| Restoration & Repair Tips Board |
Topic: Condenser
[Return to Forum]
| Author |
[Modern View]
| Unruh
08-17-2012 16:56:20
69.77.200.90
I have a 172 cui engine that I suspect needs a condenser. The one on it does not have any markings. How can I test if it's actually weak or kaput. And, if it is, are all 6V condensers the same? or do various engines use different values of capacitance? |
| JMOR
08-18-2012 08:56:57
72.181.173.171
Re: Condenser in reply to JMOR, 08-17-2012 16:56:20
| John T
08-18-2012 12:37:59
216.249.82.117
Re: Condenser in reply to JMOR, 08-18-2012 08:56:57
| | You sure got that right, yep it will still fire a spark (even with NO condensor) but indeed as I noted its a weak one. Still it would sure tickle the old ticker if you had hold of it OUCH lol We agree, its best if the condensor value is "right on" plus the points will last longer... Fun chat, take care now John T |
| John T PS
08-18-2012 05:38:48
216.249.82.117
Re: Condenser in reply to Unruh, 08-17-2012 16:56:20
| | To add to 36 Coupes excellent comment, if the condesnor value isnt close to the correct capacitance, you will observe like a pit/crater on one set of the contact points versus a build up on the other point. If however the capacitance is the correct value, while theres still normal burning and carbon, you wont see the pits versus build ups so much i.e. even wear on BOTH sides. That has to do with the condensor being the correct value to correspond to the coils inductance..... So while she can still fire with the incorrect capacitance value, its best for spark quality and points longevity if its correctly sized and not several factors off correct. CONDENSOR RATING DOES INDEED MAKE A DIFFERENCE Hope this helps God Bless yall John T |
| 36 coupe
09-02-2012 03:01:14
66.186.169.176
Re: Condenser in reply to John T PS, 08-18-2012 05:38:48
| The post on the 28 Chrysler came up when I turned the computer on this morning.I looked in my Ford Service Manual page on condenser capacity.Ford used 10 different part numbers on condensers before 1938.Most were in the .20 to.25 range, a few were.30 to.34 mfd.The condenser used on the 4 cyl Model B had a capacity of .45 to .63 mfd.Test was to be done at 250 volts.low capacity shortened point life, high capacity limited high speed performance.I have 6 nos condensers that test at .25 mfd.A note in the manual says I got it in april 1956.The ohmmeter test is null and void.I never used it.I have a model B nos condenser that tests at .50 mfd.Nos means new old stock in auto parts. |
| 36 coupe
08-18-2012 03:36:44
66.186.169.176
| The meter test wont catch a condensor that has leakage.Condensors operate at 200 to 300 volts when the engine is running.Condensors with leakage always test off rated mfd. |
| JMOR
08-17-2012 20:50:00
72.181.173.171
Re: Condenser in reply to dan mcdonald, 08-17-2012 16:56:20
| Quoting Removed, click Modern View to seeVirtually all have used 0.2 to0.3 microfarads and it is not critical. They will run even if off by a factor of 10 or even greater. Points life will be best if dead on value, but that isn't a big deal. So, hunt for one that physically/mechanically fits & be happy. |
| John T
08-18-2012 05:05:30
216.249.82.117
Re: Condenser in reply to JMOR, 08-17-2012 20:50:00
| | To add even more to that: Heck the coil will still fire even if theres NO condensor at all. If the condensor value is too large she may not fire at all,,,,,,,,,If its too small she can still fire but the sparks weaker and the points burn up sooner. Of course, if its shorted theres NO spark The condensor rating is computed based much on the inductance value of the coil which accunts for the diffrerence in values for different cars trucks n tractors which may have different inductance rated coils. For sure, diferent values of condensors will still "work" (see above) while its still better if they are at least somewhere near the correct size to correspond with the coils inductance value...... Hope this helps, best wishes n God Bless Fun chat for us sparkies at least John T |
| John T
08-17-2012 19:11:21
216.249.82.117
| | To REALLY test it for capacitance and leakage you need an actual capacitor tester. An old fashioned analog ohm meter can tell you if its bad (like its shorted out) but even if it passes, that dont mean its good under actual operating conditions. To steady state DC it should read an open circuit (once charged) and if it reads a short its BAD and will kill the spark. Yes different vehicles can use different values of condensors and its best to get the right one. It can still spark, albeit weak, if theres no condensor at all and the points would burn up sooner, but again if its a dead short theres no spark. John T |
| Unruh
08-17-2012 19:27:09
69.77.200.90
Re: Condenser in reply to John T, 08-17-2012 19:11:21
| Thanks, John, for the additional direction. Yes, it does have spark; but weak which makes me suspicious of it. My v/o meter is digital, but I'll do what I can. |
| John T
08-17-2012 19:42:50
216.249.82.117
Re: Condenser in reply to Unruh, 08-17-2012 19:27:09
| | With my oldddddddddddd Simpson 260 VOM I can set her to the R X 10,000 scale,,,,,,,,discharge the condensor,,,,,,,then attach the meter and watch the needle start to swing over to low ohms (as condensor draws current to charge up) but then KICKBACK back over to high infinty ohms once shes charged up. If the needle dont initially start over to low ohms shes not drawing current and charging and then if it dont kickback towards infinity she may be shorted or leaking........ If you dont have a capacitor tester its time for a substitution test (if you can find the right one with correct capacitance etc) n see if that helps John T John T |
| rvirgil_KS
08-17-2012 18:22:28
208.4.188.195
| | Check with an ohm meter. If shorted it's bad. If it shows ohm meter increasing let it build, then reverse leads and it should drop back to zero and then build again. If so chances are fairly good that it's ok, unless it fails after operating awhile. If it shows open it's no good. Only sure test is to replace with a known good one. New does not mean it's good. Condenser doesn't care if system is 6 or 12 volt and doesn't care if positive or negative ground. A good auto parts should be able to cross reference one to your tractor or engine. |
| Unruh
08-17-2012 19:01:46
69.77.200.90
Re: Condenser in reply to rvirgil_KS, 08-17-2012 18:22:28
|  Actually, it's a 1928 Chrysler with that 172 cid 4 cyl. Napa doesn't have a book that goes back that far, so I was "fishing" for what value, if there is one, that I could use. I once heard that one for a "H" Farmall will work,but how would I know if it's right? |
| 36 coupe
08-18-2012 03:44:17
66.186.169.176
Re: Condenser in reply to Unruh, 08-17-2012 19:01:46
| The Farmall condenser measures .15 mfd.most autos use .25 mfd.The wrong value will cause metal transfer on the points. |
| old
08-17-2012 19:25:24
209.86.226.32
| In the ignition systems there is room to go bigger or smaller as for MFD of a condenser. Take the old one in and find one that fits and your most likely to be ok. But it is not common for a condenser to go bad and they can and will last decades |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
