TractorLinks.com
Restoration & Repair Tips Board
Re: Ford Jubilee points problem
old
08-14-2012 19:35:50
Well #1 throwing parts at it is not the way to go you make more problems then you fix. First off pull the cap and rotor and dust cover. Turn the ignition on and open and close the points by hand. You should both hear and see a spark. If you do not then turn it off then pull the ignition side wire off the coil turn it on then touch the wire back to the coil then off again. Do you see a spark?? If yes and the points are closed open them and try again. With them open if you have spark the short if from the coil in. If no spark with them open or closed the points have a protective coating and it needs cleaned off
HAzman
08-15-2012 05:09:15
 Re: Ford Jubilee points problem in reply to old, 08-14-2012 19:35:50
thank you. the hit n miss way isnt working and so I'll be following your direction here. I'll let you know how it goes
