Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Restoration & Repair Tips Board
old gas tank sealer going soft and gummy
Mi-Bill
08-04-2012 08:46:47
I have a JD B gas tank with old sealer that is going soft and plugging up the gas lines and carb. Is there a way to clean out or strip the sealer? I have not pulled the tank yet?
Stephen Newell
08-08-2012 14:50:35
 Re: old gas tank sealer going soft and gummy in reply to Mi-Bill, 08-04-2012 08:46:47
I used some Red Coat fuel tank liner a couple of weeks ago and spilled some on a saw horse. Out of curiosity this afternoon I put some Kleen Strip paint and varnish remover on it and it removed it. I know just being a couple of weeks old is not really a fair test but I thought I would pass the info along.
rustyfarmall
08-05-2012 05:35:25
Muriatic acid will remove the gas tank sealers and liners.
joe fabregas
08-05-2012 05:17:27
Acetone will supposedly remove some sealers. Good luck! joe-
Stephen Newell
08-05-2012 04:17:52
What brand of sealant did you use? I've never heard of sealant going bad. I don't think any solvent would touch it. The only thing I can think to even try is to heat the tank with a heat gun and burn the sealant loose. Of course you would have to thoroughly clean the gas out of the tank like you were going to weld on it first.
36 coupe
09-02-2012 03:18:28
 Re: old gas tank sealer going soft and gummy in reply to Stephen Newell, 08-05-2012 04:17:52
Bad advise.Many sealers used alcohol as a solvent.Cork gas tank floats were sealed with shellac.Ethanol will ruin them.My 77 chevy had a Rochester carberator with a plastic float that absorbed gas.Ethanol may attack the plastic.
rustyfarmall
09-02-2012 06:38:44
 Re: old gas tank sealer going soft and gummy in reply to 36 coupe, 09-02-2012 03:18:28
Those composite floats used in many GM cars and trucks were a BIG problem LONG before ethanol was introduced. I personally replaced a BUNCH of them while working as a mechanic in the early '70s.
soundguy
08-08-2012 06:02:32
i have an allis G tank that was sealed many years back.. the new ethanol gas is slowly sofetening the sealer.. i pulled the fuel line the other day and it was packed up to the valve...
MI-B ill
08-05-2012 09:58:25
pre ethanol sealers!
