Yesterday's Tractor Co.
Shop Now View Cart
Restoration & Repair Tips Board
1953 John Deere 60
07-30-2012 11:34:53
I have a 1953 John Deere 60 that I restored about 3 years ago and have been pulling. The tractor runs great but just recently started surging when the throttle is in any position other than idle or full. I have tried readjusting but it still continues to surge. Any ideas would be greatly appreciated before I tear into it.
08-09-2012 16:35:36
 Re: 1953 John Deere 60 in reply to TaterFarmer, 07-30-2012 11:34:53
Had a 50 doing that and cleaned carb, put back on still doing it, sent carb off and had passages cleaned with a drill bit and it solved the hunting problem. Even though you think the carb is good, it can still be the problem. Gregg
07-31-2012 13:43:38
AS old has said,and as a long time 60 owner my 2 cents worth would be you have some carb problems. Probably some stopped up passageways, so a complete carb cleaning is needed. Joe
Tater farmer
07-31-2012 08:16:33
The fuel lines are all clear, I keep coming back to the governor since it don't surge at top end and low end. It sounds like the governor is hunting for half throttle.
bill mart
07-31-2012 15:14:17
 Re: 1953 John Deere 60 in reply to Tater farmer, 07-31-2012 08:16:33
binding linkages can cause hunting,real tight quarters around the cotter pins. Bill
07-30-2012 14:00:11
A lot of times that is caused by a fuel problem as in you have something clogged up some place in the fuel system
