Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Restoration & Repair Tips Board
Re: john deere 40 carburator problems? hard starting low ...
old
07-28-2012 16:02:50
Things to check before pulling out the real tools is these things. #1 check spark and make sure it is a blue/white and will jump a 1/4 inch gap. #2 check that the throttle linkage is working as it should be and not binding up some place. #3 check to be sure your air cleaner is not clogged up and or full of dirt/water. #4 open up the crab drain plug and make sure you have a good steady flow of gas out of it for a couple minutes. Catch the gas so as to look for dirt or water in it. #5 does choking it hurt or help?? If it hurts likely to be running to rich so set load needle down a 1/2 tun or so. If it help open the load needle up some
