Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Restoration & Repair Tips Board
Re: WD-45 Hydralic pump
old
07-23-2012 17:26:49
Only time my WD45 does that is when it is low on fluid so have you check to make sure your fluid level is as it should be????
Ron Holcombe
07-24-2012 07:59:20
 Re: WD-45 Hydralic pump in reply to old, 07-23-2012 17:26:49
Yeah, the dip stick kept showing empty and I would add till it was showing full. But each time I would move the front loader the oil whould show empty again. I have added quiet a bit of oil to it now but it still knocks when engaged, besides some leaks should I start to consider a new pump?
old
07-24-2012 11:50:35
 Re: WD-45 Hydralic pump in reply to Ron Holcombe, 07-24-2012 07:59:20
You need to start by finding out where all that fluid is going. Even if it is a bad pump if you loose that much fluid a new pump will not last long either find and fix the leaks then look at other thing. You may find that once you keep fluid in that the problem is no longer there
