Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Restoration & Repair Tips Board
Re: Best kind of oil??
JRSutton
07-16-2012 16:25:00
Unless the engine has recently been rebuilt, I wouldn't hesitate to go to 40, especially during the warmer months.
It should give you better compression and coat worn parts better - and increase oil pressure if your pump is getting worn.
A DeWitt
07-16-2012 17:30:20
 Re: Best kind of oil?? in reply to JRSutton, 07-16-2012 16:25:00
So switching from 30 wt to the 15w40 should help the engine then? I just wasn't sure about going from non detergent oil to regular detergent oil.
ASEguy
07-17-2012 12:43:56
 Re: Best kind of oil?? in reply to A DeWitt, 07-16-2012 17:30:20
Run detergent oil. The weight depends on the temperature where you are and the oil pressure of the engine. Most engine wear occurs at start-up so a multigrade would be fine.
old
07-17-2012 08:28:18
Another one of those myths that say if you run non-detergent oil you can not switch or it will clog things up. Ya it may break a bit of it down but the filter will catch it and be goner in one or 2 oil changes
