TractorLinks.com
Restoration & Repair Tips Board
Re: 560 farmall problems???
LaDuke Farmall
07-13-2012 16:52:46
I started with fuel. I replaced the bulb on the tank, and cleaned the tank out when I did that. I put on a new fuel line and filter as well. Then I rebuilt the carb. I have good fuel flow to the carb. Nothing changed so I started to test spark and found that I had none on any of the plugs. from there I put points, coil, resistor, and a new battery in it. Still no fire. I am stumped at this point. I have been using a volt meter to check voltage with, and all I read is zero. But its hot to the coil. Thanks for any advice you could offer
