Yesterday's Tractor Co. Compare our Prices For Parts
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Restoration & Repair Tips Board
Topic: 560 farmall problems???
[Return to Forum]
LaDuke Farmall
07-12-2012 17:39:40
67.142.181.25
I got a 560 farmall. has been running fine until about a week ago. I had to dive it back to the house in 1st with the choke on. I have rebuilt the carb and checked the timing. I put new points, plugs, cap and rotor on it. then I put a new coil and resistor on it. whats got me is it turns over great, and I have power to my coil but not to the distributor. am i over looking somthing small? Thanks if anyone can help on this
[Reply]   [No Email]
Andy C
07-19-2012 16:14:57
74.103.166.115
 Re: 560 farmall problems??? in reply to LaDuke Farmall, 07-12-2012 17:39:40
Did ya find anything out?
[Reply]  [No Email]
LaDuke Farmall
07-24-2012 13:55:05
67.142.181.25
 Re: 560 farmall problems??? in reply to Andy C, 07-19-2012 16:14:57
yes I did and thanks for the help. The wire going from the coil to the dist was rotten most the way. I made a new wire and she seems to be running fine. Its always the small things that give you the most trouble. Thanks
[Reply]  [No Email]
Fixerupper
07-15-2012 08:43:30
100.42.82.164
Andy's advice is exactly what I would have said for checking spark, cuz I do it that way often. One addition to that advice is to make sure the screwdriver blade isn't touching metal when you push the points open. Another self-taught bit of advice is to make sure your pointer finger hasn't slipped off the plastic screwdriver handle and is touching the metal shank of the screwdriver. Doesn't shock you real bad but it wakes you up.
Your real problem is an engine that's being starved for fuel. Maybe a floating piece of junk made it's way to the main jet. Jim
[Reply]  [No Email]
Andy C
07-14-2012 08:05:22
71.246.21.89
OK...Take dist cap off and take the wire out of the middle that goes to the coil. Leave the wire in the coil. now, look closely at the points and condenser to make sure none of the wires are touching ground where they are not supposed to. If all looks good there (here is where ya got to pay attention to what you are doin) Look to see that the points are closed....if not turn the engine over a little bit till they are closed. Turn the ignition on and gently open the points with a plastic handled screwdriver. You should see a faint little spark at the points gap. If you do then with another insulated screwdriver or appropriate INSULATED device get the end of that wire coming off of the coil near 1/8-1/4 inch from the block or another good ground and while holding it there gently open the points. You should get a nice blue spark every time you open the points (assuming the coil wire is that 1/8-1/4 distance away from the ground) If you have arrived at this point and have a hot spark you likely have a bad distributor cap or fouled plugs. If you didn't get spark perhaps the condenser in the distributor is bad.That is the down and dirty way to troubleshoot. Try it out and post back your findings so we can narrow it down.
Andy
[Reply]  [No Email]
LaDuke Farmall
07-13-2012 16:52:46
67.142.181.22
I started with fuel. I replaced the bulb on the tank, and cleaned the tank out when I did that. I put on a new fuel line and filter as well. Then I rebuilt the carb. I have good fuel flow to the carb. Nothing changed so I started to test spark and found that I had none on any of the plugs. from there I put points, coil, resistor, and a new battery in it. Still no fire. I am stumped at this point. I have been using a volt meter to check voltage with, and all I read is zero. But its hot to the coil. Thanks for any advice you could offer
[Reply]  [No Email]
Andy C
07-12-2012 18:27:51
74.103.166.115
Your description of having to have the choke on would indicate a fuel problem. Do you have a good flow of gas if you disconnect the fuel line at the carburetor? Did you check the fuel filter going into the carb? After that I would take the drain plug out of the bottom of carb and check fuel flow there. What are you checking the voltage on the coil with? The points open and discharge the coil so you would not have constant voltage on the wire going to the points. My vote is a fuel problem. Post back an let us know what you find....we may all learn something!
Andy
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
