Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Restoration & Repair Tips Board
Re: Need to move John Deere A clutch from right to left side
Bob M
07-11-2012 09:07:30
Ray - Ask around for a good mechanic or welder/fabricator. Should be a straight forward job to mount a cross shaft and linkage to reposition the clutch handle to the left side.
While you are at it you might want to have him make a new clutch lever perhaps 6" or so longer than original to lessen the effort required to snap the clutch in/out.
This post was edited by Bob M at 18:37:23 07/12/12.
Meangreen
07-12-2012 07:01:00
 Re: Need to move John Deere A clutch from right to left side in reply to Bob M, 07-11-2012 09:07:30
My first A had the lever lengthened and it was pretty slick, so my dad and I did the same thing on my B. I have noticed on the B with new cluch plates that it can sometimes be a little hard to get the clutch to disengage with the longer lever. I think the longer lever tends to bend a bit more than the original length one. I like to plow and stuff, so I probably run my clutch a little tight. I"m 6"6" so that"s why I like the longer lever.
My only question with the "V" add on is will the pedestal or dash get in the way?
Bob M
07-12-2012 18:57:04
 Re: Need to move John Deere A clutch from right to left side in reply to Meangreen, 07-12-2012 07:01:00
We have a couple A's we use to pull hayride wagons at a friend's Christmas tree farm. The older one (a '47) has a short clutch lever; the other (a '53) has lever about 6" - 8" longer.
I much prefer the longer one. It requires much less force to snap in/out. It's also easier to modulate for smooth starts, and is easier to operate while standing up.
RayAtLost ShoeRanch
07-12-2012 06:23:56
Great idea. I'll look into it. Thanks!
