TractorLinks.com
Restoration & Repair Tips Board
Re: Stuck Clutch on a Ford 600 series
Farmerhr
07-08-2012 22:49:42
If the excellent suggestions do not work, you might try taking the starter off, place a 90 degree bent sharp bar between the pressure plate and clutch plate, and then have some one strike the bar with a hammer. I have freed up several stuck clutches this way. Not sure if it will work on a 600, but it is worth a look. Please email me if I can be of additional help.
Thanks !
Solar_Guy
07-09-2012 15:34:51
 Re: Stuck Clutch on a Ford 600 series in reply to Farmerhr, 07-08-2012 22:49:42
All,
Thanks. I used some of the suggestions and read through the forum archive and got the clutch freed up today by blocking the clutch down yesterday and putting it in 4th today and tugging on it a bit with a truck. freed up and seems to work good. Thanks again.
Kevin
old
07-10-2012 11:53:15
 Re: Stuck Clutch on a Ford 600 series in reply to Solar_Guy, 07-09-2012 15:34:51
To make sure it does not happen again it is a good idea if your going to park it for any time at all the block the pedal down. Doing that does not hurt any thing and I have an 8N that has the pedal blocked down right now and I have not run it in at least 9 months
