TractorLinks.com
Restoration & Repair Tips Board
Differences in JD/IHC Carbs
Farmallb
07-05-2012 13:06:34
Im wanting to know which one is more complex, a carb off of a 48 H Farmall, or a carb off of a 39 A JD?
Tramway guy
07-07-2012 11:51:25
 Re: Differences in JD/IHC Carbs in reply to Farmallb, 07-05-2012 13:06:34
Ahh, but is the spark coming at the right time??
rustyfarmall
07-08-2012 08:44:26
 Re: Differences in JD/IHC Carbs in reply to Tramway guy, 07-07-2012 11:51:25
Ignition systems do sometimes have a secret passage, which is not particularly a GOOD thing, and more often than not can be quite a chore to track down and plug.
bill mart
07-06-2012 13:52:25
secret passages on the deeres
rustyfarmall
07-07-2012 06:12:07
 Re: Differences in JD/IHC Carbs in reply to bill mart, 07-06-2012 13:52:25
Secret passages on the IH carbs also, but they are slightly more accessible than the JD carbs.
rustyfarmall
07-05-2012 13:19:51
They are equally complex and each will have it's own little differences and challenges. No such thing as a "simple" carburetor.
Farmallb
07-06-2012 10:31:25
 Re: Differences in JD/IHC Carbs in reply to rustyfarmall, 07-05-2012 13:19:51
I bought a can of starter spray. Took the top cap off the carb and sprayed it. Nothing happened with it running off a belt to another tractor idleing. I had the mag redid, and I checked it yesterday, and its getting spark. Could I take off the carb and just spray into the inlet??
36 coupe
09-06-2012 17:51:21
 Re: Differences in JD/IHC Carbs in reply to Farmallb, 07-06-2012 10:31:25
Starter spray is bad stuff.I think it fires on compression with out a spark.Best not to use it.
