TractorLinks.com
Restoration & Repair Tips Board
Re: blue exhaust
rich o
07-03-2012 17:49:08
help!!! my terrible blue smoke has stopped ,but has been replaced with haenous white /greyish smoke,very heavy., i hope the neighbors dont call the epa. it has also lost significant power and seems to be knocking and ideling rough, this has all happened after 7+ hours of light tedding on flat ground. i was advised not to do guides by the machine shop that did the valves .,something about losing the centers. so has my winter project become a nitemare when i really need it most?. i dont do alot of haying in the winter, after all this is vermont
buickanddeere
07-12-2012 09:11:01
 Re: blue exhaust in reply to rich o, 07-03-2012 17:49:08
May have a sleeve sitting high. Did you check each one or did you just pound the sleeves and pistons in then torqued down the head? Re-used or new head fasteners? Some old fasteners won"t take a 2nd torquing and provide sufficient tension. Don"t putt around with a rebuild, take it out and work it. Must have been some sort or miss communication with the shop about the cylinder head. Install new guides then cut the seats true. Couldn"t imagine having the head off a gasser and not replace guides, new exhaust seats if required and a valve job.
Dave_Id
07-12-2012 07:45:03
Did you retorque the head bolts after initial run? Try that first, if you still get white smoke pull the head, minimum head gasket is leaking, perhaps flipped upside down..or bad head gasket... I'd hate to think what else could be wrong.....
JRSutton
07-06-2012 10:02:12
That would be water in the cylinders.
Something's definitely wrong there.
I'd pull the head and see what's up.
Do a quick compression test first before removing the head to see if you can identify where the main problem is.
Could just be bad/incorrect head gasket. Could have been getting oil in that way - followed by water later.
patsdeere
07-03-2012 22:46:01
I would stop running it with white smoke and check for water. Could be very bad.
