| Restoration & Repair Tips Board |
Topic: blue exhaust
[Return to Forum]
| Author |
[Modern View]
| rich o
07-02-2012 12:25:45
66.220.233.8
just put my engine rebuild of my massey 65 to work and it seems to be smoking bluish ehhaust, i thought it would burn off but it has not, whats up. i did pistons/ rings /sleeves / bearings /valve job.also set the timing to what i thought was done correct. why does this colored smoke appear |
| rich o
07-03-2012 17:49:08
66.220.233.8
Re: blue exhaust in reply to rich o, 07-02-2012 12:25:45
| help!!! my terrible blue smoke has stopped ,but has been replaced with haenous white /greyish smoke,very heavy., i hope the neighbors dont call the epa. it has also lost significant power and seems to be knocking and ideling rough, this has all happened after 7+ hours of light tedding on flat ground. i was advised not to do guides by the machine shop that did the valves .,something about losing the centers. so has my winter project become a nitemare when i really need it most?. i dont do alot of haying in the winter, after all this is vermont |
| buickanddeere
07-12-2012 09:11:01
184.151.63.206
Re: blue exhaust in reply to rich o, 07-03-2012 17:49:08
| May have a sleeve sitting high. Did you check each one or did you just pound the sleeves and pistons in then torqued down the head? Re-used or new head fasteners? Some old fasteners won"t take a 2nd torquing and provide sufficient tension. Don"t putt around with a rebuild, take it out and work it. Must have been some sort or miss communication with the shop about the cylinder head. Install new guides then cut the seats true. Couldn"t imagine having the head off a gasser and not replace guides, new exhaust seats if required and a valve job. |
| Dave_Id
07-12-2012 07:45:03
75.92.58.173
| Did you retorque the head bolts after initial run? Try that first, if you still get white smoke pull the head, minimum head gasket is leaking, perhaps flipped upside down..or bad head gasket... I'd hate to think what else could be wrong..... |
| JRSutton
07-06-2012 10:02:12
75.130.109.233
| | That would be water in the cylinders. Something's definitely wrong there. I'd pull the head and see what's up. Do a quick compression test first before removing the head to see if you can identify where the main problem is. Could just be bad/incorrect head gasket. Could have been getting oil in that way - followed by water later. |
| patsdeere
07-03-2012 22:46:01
69.181.80.2
| I would stop running it with white smoke and check for water. Could be very bad. |
| Jerry/MT
07-03-2012 10:33:14
206.183.116.145
| | I agree with the others. If it"s a gasser and if he smoke appears heavy at idle, and less at higher powers, it"s the valve guides. If it"s a diesel and the rings have been worn in (~ 10-20 hrs of operation through the power range)then it"s probably oil past the valve guides. |
| greygoat
07-03-2012 06:04:59
184.158.75.173
| rustyfarmall
07-03-2012 06:24:21
67.55.162.174
Re: blue exhaust in reply to greygoat, 07-03-2012 06:04:59
| Worn valve guides will usually result in blue smoke only for a few seconds after starting the engine, and then it clears up. |
| rustyfarmall
07-02-2012 13:54:16
67.55.162.174
| Those new rings have not yet seated in. Probably need to work it HARD for a few minutes. |
| JRSutton
07-02-2012 18:26:10
75.130.109.233
Re: blue exhaust in reply to rustyfarmall, 07-02-2012 13:54:16
| | and if that doesn't work - start to worry. Blue smoke = oil burning, no two ways about it. Was it smoking before you rebuilt it? Does it smoke constantly? There's a chance it's coming in through the valve guides - you didn't mention doing any head work/new valve seals. That usually shows up intermitttently though. |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
