Dwight Tuttle
New User
I have a 1949 JD Model A, with generator. I have had the Generator rebuilt twice. Two new Voltage
Regulators. I have rewired, from the Generator to Amp Meter. I cannot get the Amp Meter to show either a charge or discharge, unless I short a wire. The Generator is showing 13.3 volts and 5 amps on a test bench. I have one wire from the battery side of the regulator going to the Amp Meter. Another wire, from the battery to the other side of the Amp Meter. Both wires are hot with electric current. The Amp Meter is brand new and I borrowed another Amp Meter that also did not show anything. I even tried a new battery. Any help would be greatly appreciated.
Thanks, Dwight in NM.
