| Restoration & Repair Tips Board |
Topic: Amp Meter
[Return to Forum]
| Author |
[Modern View]
| Dwight Tuttle
07-01-2012 22:56:31
97.123.91.17
I have a 1949 JD Model A, with generator. I have had the Generator rebuilt twice. Two new Voltage Regulators. I have rewired, from the Generator to Amp Meter. I cannot get the Amp Meter to show either a charge or discharge, unless I short a wire. The Generator is showing 13.3 volts and 5 amps on a test bench. I have one wire from the battery side of the regulator going to the Amp Meter. Another wire, from the battery to the other side of the Amp Meter. Both wires are hot with electric current. The Amp Meter is brand new and I borrowed another Amp Meter that also did not show anything. I even tried a new battery. Any help would be greatly appreciated. Thanks, Dwight in NM. |
| John T
07-02-2012 14:28:49
199.190.54.237
Re: Amp Meter in reply to Dwight Tuttle, 07-01-2012 22:56:31
|  To Polarize jump from BAT on the VR to GEN/ARM NOTTTTTTTT to FLD Heres the wiring if its a Cutout Relay system: http://img.photobucket.com/albums/v437/M-MAN/SM-2029/A-2-JPEG.jpg Heres the wiring if its a Voltage regulator System: http://img.photobucket.com/albums/v437/M-MAN/SM-2029/A-3-JPEG.jpg Heres how to Troubleshoot if shes not charging: http://www.ytmag.com/cgi-bin/viewit.cgi?bd=farmall&th=665110 Questions:??? John T |
| Dwight Tuttle
07-02-2012 22:04:29
97.123.91.17
Re: Ammeter in reply to John T, 07-02-2012 14:28:49
| John, Thank you for your reply. I printed out, what you sent me, and I will see what I can do in the morning. If I turn on the lights, the ammeter shows a slight discharge. If I engage the starter, it doesn't show anything. I installed a brand new 12 volt battery, about a month ago. All new wiring was installed on the generator, by the people, that rebuilt the generator. I have a three post voltage regulator on the front and one post on the back. The VR is new. Both post on the ammeter are reading electric hot. The field wire from the VR goes to the light switch. When it was on the test bench, it showed 13.3 volts and 5 amps. Would it still need to be Polarize? I do have a Mag with positive ground. John, thanks again and Blessings. Dwight in NM. |
| John T
07-03-2012 06:12:57
199.190.54.237
Re: Ammeter in reply to Dwight Tuttle, 07-02-2012 22:04:29
| | If its a 3 terminal (BAT FLD GEN/ARM) or a 4 terminal (BAT LOAD FLD GEN/ARM) THERE SHOULD BE NOOOOOOOOOOOOO WIRE TO THE LIGHT SWITCH !!!!!!! On many 4 terminal VR's BAT LOAD FLD are side by side while GEN/ARM is underneath or off on one side all by itself If its a 2 wire (BAT GEN/ARM) Cutout Relay then the gennys FLD does wire to the light switch. SOUNDS LIKE IT MAY NOT BE WIRED RIGHT !!!!!!!! It may be polarized at neg ground at the shop but now youre at Pos ground so be sure to polarize BEFORE STARTING Im headed to the Colorado mountains so may not have net for a while. Look at the diagrams and what I said in both my posts John T |
| Dwight Tuttle
07-02-2012 11:19:43
97.123.91.17
| I took a short wire, from the battery to the field on the regulator to polarize the generator. I'm going to try it again. Dwight in NM |
| JMOR
07-02-2012 07:19:32
99.163.118.55
Re: Amp Meter in reply to MH tractor, 07-01-2012 22:56:31
| Quoting Removed, click Modern View to see"I have one wire from the battery side of the regulator going to the Amp Meter. Another wire, from the battery to the other side of the Amp Meter."
OK, but where wre wires from gen/reg tied into the ammeter? Nothing else should connect to ammeter side(terminal) with battery. All charging current, loads, etc. should be conected to 'other' ammeter terminal, i.e., the terminal that is not connected to battery. |
| Dwight Tuttle
07-01-2012 23:22:10
97.123.91.17
| Also I should have stated, that the field wire goes to the light switch and is hot. the rest of the wires,on the generator, were rewired by the generator rebuild shop. Dwight in NM |
| JMS/.MN
07-02-2012 07:02:02
209.237.107.155
Re: Amp Meter in reply to Dwight Tuttle, 07-01-2012 23:22:10
| Did you polarize the generator after installation? |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
