TractorLinks.com
Restoration & Repair Tips Board
How to remove rust behind serial tag on Lp tank
jd 70 puller
06-29-2012 19:45:44
I want to know how to remove rust behind serial tag on an lp tank? grind off tack welds and re weld or use some kind of acid?
Andy C
07-04-2012 18:06:40
 Re: How to remove rust behind serial tag on Lp tank in reply to jd 70 puller, 06-29-2012 19:45:44
You can search it on the internet. Basically get a small DC power supply (an AC adapter will work with a small piece of metal such as the tag)put the chemicals in a plastic container. Make sure you are hooked up correctly so you don't sacrifice the tag.Put it in the solution and let it do its work.Here is a link to get you going in the right direction.
Good Luck,
Andy
Andy C
07-01-2012 06:27:56
I Have the same problem (70, 730 LPs)...Grind the tack welds off, Electrolysis the tag, clean up the place where the tag goes and then JB weld the tag back on after you have rounded the corners where the tack welds were. If you get a nice bed of epoxy the moisture and air will not get in there and you should be good to go for a long time.
Good Luck,
Andy
Jd 70 puller
07-02-2012 07:53:40
 Re: How to remove rust behind serial tag on Lp tank in reply to Andy C, 07-01-2012 06:27:56
Thanks andy, how do I do the electrosis?
