Yesterday's Tractor Co.
Shop Now View Cart
Restoration & Repair Tips Board
Re: Electrolysis
06-25-2012 21:43:25
Here's an update on the project: I have drilled a hole thru the hub (cast iron with steel spokes cast into the hubs) and apparently hid a"void". I've been filling the hole with "Liquid Wrench" and/or PB Blaster and occasionly appying heat with a propane weed burner. Been doing this off and on for the last month (more off than on!). So, this evening, I tapped the hole to 1/4-28 thread for a small Zerk. I then filled the hole with some penatrating oil, screwed in the Zerk, and applied pressure with the grease gun. I rounded up the weed burner again, and proceded to heat the hub. Didn't get it red hot, but good and smoking hot. I also applied some more pressure from the grease gun a couple or 3 more times. I then noticed some of the oil/grease beginning to seep out around the axle/hub on the outter end of the axle. Can't see the inner side!!!! So..apparently I'm on to something. The wheel still isn't free, but will let it cool and see what happens. Perhaps this method will help someone else.
By the way, I still have 3 more wheels to go!!!! I'll let you all know how this battle goes. Jon
