TractorLinks.com
Restoration & Repair Tips Board
massy Ferguson to 35 with z 134 gas engine
245 rv
06-21-2012 19:20:30
i bought a to-35 from a guy with a complete rebuilt motor,done by a napa machine shop,the governor does not work i have done the steps in the manual 2 times ,there is no motion on the governor rod it does not push when you throttle up with my ford you can grab it and push the governor rod and feel it push back down the massy is dead no force is felt am i right that it has to be internal under the cover,with the governor assy itself i am going to split the front and remove cover what should i look for,what can go wrong it is a new governor,what are the steps to put one in ,thanks
Dave in Tx
07-01-2012 19:56:20
 Re: massy Ferguson to 35 with z 134 gas engine in reply to 245 rv, 06-21-2012 19:20:30
when you cut the engine off, the govenor arm should go to full throttle. Hold the carb wide open and the rod from the gov has to bolt to the carb at that position. to short it will run wild, too long the gov will hunt or surge like mad.
Gilbert in IL.
06-25-2012 10:52:39
....Sorry, Harry Ferguson forum!
Gilbert in IL.
06-24-2012 21:17:38
Hey 245, drop down to the massey-harris forum....I`ll BET John(UK), IF not others will help ya out!!! You`ll get quicker `sponces.....GAS
60 acre hillside
06-22-2012 05:22:23
Governor spring
245 rv
06-22-2012 08:00:48
 Re: massy Ferguson to 35 with z 134 gas engine in reply to 60 acre hillside, 06-22-2012 05:22:23
inside the front cover or one of the 2 you can see,,,,,when engine is running there is no force on the governor arm at all,when you rev it up that arm should push back with resistance right,,,,
245rv
06-23-2012 18:08:02
 Re: massy Ferguson to 35 with z 134 gas engine in reply to 245 rv, 06-22-2012 08:00:48
spent the hole day on this tractor found the tab on the governor cone was not in right place,put back together still dont work but i do now have force pushing on governor shaft as soon as i hook up rod to carb it runs way to fast nothing is binding i think the compensating spring may be wrong,its vary stiff,and the governor can not pull it im getting a new one and trying that,,,does anyone have a pic of were that tab goes on the cone my book says put tab at 8 oclock ,,,,,,,,,,,,,,,what should it ride on,,,,,,,,
245rv
06-24-2012 12:48:17
 Re: massy Ferguson to 35 with z 134 gas engine in reply to 245rv, 06-23-2012 18:08:02
ok this thing is getting the sledge hammer soon ,,,i start the motor,disconnect the throttle rod ,hold the governor forward and it pushes my hand like crazy,put the throttle rod on and it will not push it to a idle,it idles but if i pull the throttle at all it revs to the moon,,,,,, with no responce from the govener i dont get it the rod to the throttle plate moves free,there is no reason it wont push the throttle rod back,,,,,,,,,,,,,,,,,,,,,,
